1 - 6 of 6 Posts
OK, I've searched and read my Haynes manual. Still not for sure where the temp sensor is supposed to be:
Is it right under the water gooseneck? Perpendicular to the long-axis of the crankshaft?
OR
Is it on the front of the intake manifold, under the runners and parallel to the engine?
Of course, it might make a difference that my truck is a 2.6 with a carb. Not sure if it is a 2.3 manifold or 2.6. That's the only gauge not working at this point and probably the most important one...
Temp sensor is on the intake, right near the thermostat and water outlet, sort of on the lower front side. I believe it is parallel to the motor, pointing at the radiator. It isn't very big, half inch around or less. I had to look for a while to find it the first time myself.
The last Trooper (86 w/2.3L) I got had the little tab on the end broken off on of the sensor. I found it stuck in the connector on the wire that is 'supposed' to be hooked to the sensor. That happen to you as well? I'm just curious if that is a common problem.
Not sure, there wasn't much sticking out. Just enough lip to hang a fingernail on. The whole thing was out maybe 1/16" from the end.
It should have a fair bit sticking out toward the front of the truck, like close to (but under) a half inch. The tab should have enough room to hook on a spade style wiring connector and still have a 1/8" or so left over. Sounds like yours is broken off about the same as mine was.
I had a spare available but I figured to fix the broken one by soldering a wire directly to the sensor with a connector on the other end. Maybe cover it all with heatshrink tubing. It looks like it just hangs out in the way a little too much so it is easy to break it. Earlier Isuzu motor designs had the sensor under the intake and used a stouter connector style that did not stick out.
1 - 6 of 6 Posts
