1 - 8 of 8 Posts
Can somebody that has a 2.8 trooper help me out with this wire? After having my engine out for three years this is the only one I can't remember where it goes.
no, this is the on pass side. It looks like a ground but I can't for the life of me figure out where it goes. It runs without it hooked up..
It comes from the main engine harness, on the trooper side before the engine harness plugs are.
Looks like it would either be a ground or power to something from a fuse box. Use an ohm meter between it and the frame or some other ground point to see if its a ground or has resistance through something.
I will go look, I just realized I posted the same ? about a year ago. I was working on a friends Trooper and found the same wires under the battery tray. Be right back. Okay it is a ground that bolts to your motor mount bracket you can see it from the bottom there is corner sticking out that has a thrd hole in it. If you don't find it let me know I can take a picture. Dave
Thanks man!!!!
yup that one is good to go...
1 - 8 of 8 Posts
