1 - 4 of 4 Posts
My axel position switch wire has ripped out 3 times now!!! I’ve been soldering it back together but I really need to buy a new one. Where can I buy one of these??? Thanks.
Font Art Graffiti Automotive lighting Graphics
Rectangle Font Mesh Pattern Wood
The switch is identified as Switch; Differential, Honda/Acura/Isuzu part # 8-97101-956-2.
There an 0-ring that goes with it identified as Gasket; Switch part # 9-09571-414-0.
The switch is listed as discontinued but there may be an aftermarket replacement. Start searching using the part number.
Hey quick question. Does my TOD still work even if the switch wire is broken??
The axle switch tells the TOD electronic control module that the front axle is in 4WD configuration. The attached chart suggests the transfer case will not send torque to the front axle when TOD (4WD High range) or 4WD Low range is selected.
Rectangle Font Parallel Slope Circle
1 - 4 of 4 Posts
