1 - 10 of 10 Posts
i have an 88 pup what axles are easiest to swap and what works best?
Any axle will work seeing as how youve got to cut the IFS out regardless. Im going to be using a dana 44 for my trooper since I have one.
For a correct width axle Id say either a bronco or wagoneer dana 44 or a toyota mini truck axle. If your building a hardcore crawler then just go straight to full width one tons. Dana 60 up front 14 bolt full floater in the rear. No reason to put a full width dana 44 up front just to realize later your gonna break it all the time on 38+ tires.
do they work well with the stock powertrain?
With the right gearing. It will take a little fab work any way you do it.
There are a few SAS projects on here you can use for reference.
Why would you say your gonna break axle shafts(i assume you meant these) on the dana44?
jstader45 ----- as far as the topic is concerned, you can look at my build post(see my signature area) to give you an idea of what you will be getting yourself into!!
thanks alot that thread will come in handy!
I would say youre gonna break dana 44 axle shafts on a 38in + tire because ugh you're gonna break dana 44 axle shafts on a 38in + tire...
Dana 44 under a mid size rig such as ours is only good to 35s w/ no after market shafts, 37 w/. Anytime you get bigger than that 37x12.5 on that axle its too much weight and too much leverage and is time for a dana 60. Dont buy into the BS people try to sell on the internet that my cousins brothers uncles sisters brother ran 44in tires on a dana 44 front with a big block in a fullsize chevy and never broke a thing. Cause if they didnt break that they didnt wheel it.
Agreed. D44's are not that strong. Along with breakage consider the stopping power the D44 will have with a 38" tire. You will want a D60 with tires that big.
1 - 10 of 10 Posts
