Hi All,
I have some 2" coil spring spacers on order for my Wifes 2004 Axiom (TOD), which will be used with a 1.5" torsion bar lift.
I was wondering if you all thought we would be ok using a 265/65/17 tire (about 30.5" tall) with this lift?
If so, will this tire size be ok on the factory 17x7 wheel, or is it too wide?
If a 265 is too wide, what size tire would you recommend on the factory wheel?
Also, do I need to "upsize" the Spare Tire as well, to prevent problems with TOD and the Limited Slip Diff in the event of a flat?
Thanks for any info you can priivde!
