1 - 3 of 3 Posts
What is it called and where can i get one?? I didnt notice it missing when i put my cv back in... now my wheel bearing is full of mud and destroyed..
Knuckle oil seal. http://WWW.myisuzuparts.com lists pn as 8-94407-725-1 for a 10-1991 to 01-1995 Trooper, and pn 8-97123-691-0 for a 02-1995 to 05-1996 Trooper. If you want an Isuzu oem seal, I'd send a pm to JLemond. Double check my part numbers just to be safe if you order one someplace other then Jerry, Jerry won't need no stinking part number, they're in his head. :)
Since you'll have this apart again anyway, at least check the knuckle bearing as well. Or better yet, buy one with your seal, they aren't that much and you'll have it on hand if you need it...likely from your description.
Thanks! Ill check to see if i can get it locally, I need it soon as im not putting new wheel bearings in without it. If i cant, ill hit up Jerry :D
1 - 3 of 3 Posts
