1 - 3 of 3 Posts
I don't think I'd know one if it bit me. What to look for? What would fit an '86 Trooper?
Thanks
you should be looking for the factory code G80 on the firewall and also mine has a sticker on the rear diff saying to only use lsd oil. as far as no stickers telling one 3rd from another im not sure there is a way aside from pulling it apart.
The only lsd that will fit your '86 10-bolt is from a late '80's turbo Impulse, you'll have to have the lsd carrier swapped to your housing/ring gear for the right ratio.
You could swap in a later axle assembly that was available with lsd but it would be 4" wider than your current axle.
1 - 3 of 3 Posts
