1 - 16 of 16 Posts
I recently had a buddy come to me wanting a set of u-bolt eliminator plates for his Samurai. I created a few patterns in the computer & cut them out. Turned out great.
They are basically a 5x6" plate that welds to the top of the axle tube. The 2 plates bolt around the leaf spring pack, sandwiching it in against the axle bracket.
I'll get some pics when I go out to the shop after work today. I am ready to start cutting/welding/shipping these brackets. Curious to know if there is any interest out there.
They basically look like this
What exactly is the advantage over u-bolts?
Looks alright. But if that is the finished product I would put the bolts right against the leaf spring pack. It will put less bending load on the plates.
I agree. I would also add another set of bolts to make a row of 3 on each side.
If you have enough lift your pinon angle will be changed. My friend had probably 4" of angle blocks just to get his pinon angle close. After installing the brackets his vehicle drives much better.
The only way I see that these could correct a pinion angle is if the spring perches were welded to the axle tube at the corrective angle during install. You could get the same thing rotating the spring perch & keeping the u-bolts.
Again, what is the advantage? With the SOA pictured you would gain the diameter of the u-bolt in ground clearance where the u-bolt would be snugged against the bottom of the axle tube, but what else? Maybe the increased contact patch with the spring leaves reduces axle wrap a bit?
How does that set pinion angle any differently than a U bolt?
But you have to weld that new perch on correct?? Isn't it the same amount of work to just put new spring perches on at the new pinion angle and keep the U-bolts?
Exactly. The pinion angle is controlled by the welding of the perch, not by the bolts or that plate.
These plates are the spring perches. I don't understand why this is such a difficult concept to understand.
If you like u bolts... Then keep them.This mod is for the select few that have extensive modifications such as an aftermarket rock crawling axle. Nobody is saying that this system functions better than u bolts, it's simply a matter of personal preference.
I just don't understand the point. What's the advantage over a U bolt?
Right, just like with a U bolt. So what's the difference? Is this stronger or something?
I know its sounding like were being asses but were really not. You asked if there was any interest in this kit and we are just trying to get any idea of what it does different. And these wont be of much help in isuzus with them all being spring under axle from the factory. Really we are just trying to understand the benifit.
Like he said there is no benefit. Simply preference. One plus I can see is if you do hard off roading and damage the threads and need to remove the axle frequently then the bolts could be cut and easily replaced.
1 - 16 of 16 Posts
