1 - 6 of 6 Posts
Okay so my dad 03 volvo s60 is getting alittle boring now. Lol does anyone know how to "turn up" or increase the boost? It might be a stupid question but I mean I know more boost = I go faster :). I know you can go too far but I wanna run like 8-10psi if possible. Maybe more. But what's all required?
is this the volvo trooper or the volvo rodeo that you're talking about?
you might want to put this in the "other vehicles" section :wink: :wink:
cheers
Lol thanks man. Sorry bout thatt forgot we even had one
Yes! There is a way.
It's called iPdUSA.
My fiancee' has an '01 V70 T5 Wagon and I use that as my turbo toy. Sleeper: definitely. Her T5 is a high pressure turbo compared to your low pressure turbo though so tuning is a little different. The T5 can be bumped from the stock 10psi to 18psi. That's 280hp and 320 ft/lbs of torque.
Your low pressure turbo can be bumped from the stock 8psi to 14psi. It's 230hp and 275 ft/lbs of torque.
One problem...it's not cheap. :)
Pro. How is this done? I was reading you can't put a BCS on volvo s60's?
First off, your Volvo does not use a BCS. Instead, it uses a TCV (Turbo Control Valve). It's a little different but the theory is the same. Boost can be increased easily via the ECU. Typical chips/flashes run in the $300-800 range.
Second, this is an Isuzu forum. :) I highly recommend asking ANY of the Volvo forums. Just do a quick google search and you'll find lots.
1 - 6 of 6 Posts
