1 - 4 of 4 Posts
I have installed a 2" coil spacer in the rear and am planning to do a ball joint flip in the front together with adjusting the torsion bars to gain an additional 2" in the front. I am also installing some Pro-Comp ES3000 shocks in the front and back.
My question is should the ball joint flip be enough to properly align the front tires or is a ball joint spacer required? Also will the ES3000 shocks work ok with the 2" lift?
You will get minimal if any travel increase from the flip and or spacer. This has been debated many times, so opinions vary. People have been searching for increased front travel for a long time. Nothing you can really do, at least that I know of.
Andre
1 - 4 of 4 Posts
