1 - 4 of 4 Posts
I had a custom front tube bumper made which eliminated my factory turn signals. I'm looking to make the marker/running lights the turning signals also. After doing some searching... I noticed that the 1998+ Rodeos use a marker light/turn signal combo. Then I also noticed it looks very similar in design to my factory marker light.
Does anyone know if the newer marker lights will fit the older 1991-1997 rodeos?
look this up and ask them. they'll give you an arms length worth of information.
danielsternlighting.com
good luck
Not sure if they will swap different mount setups for sure
Options off top of head
1)drill another hole and run wires from bumper area into new hole
2)get a double socket like an 1157 and just cut wires and solder to new leads and then make it fit into the hole
Yeah. The mounts look fairly similar based on pictures... But don't know without actually comparing them. Yes, that's the other option I'm looking into.... Good thoughts. :)
1 - 4 of 4 Posts
