1 - 3 of 3 Posts
Symptom of a few things.. however MAF sensor is normally the fault. to test the MAF simply unplug it & start the engine. Will will be harder to start but it will start and level out. If the problem continues afterwards then, the MAF sensor is fine. Id the problem goes away then the MAF is dirty or faulty.
Thank you, I will try that.
1 - 3 of 3 Posts
