Hey guys! I'm brand new to your forum and first of all I would like to greet all of you Trooper/Isuzu-enthusiasts.
I bought my '91 Trooper I 4 months ago and since then started a big restoration project with him.
I made huge process already but now stumbled over a problem where I am slowly but surely getting crazy and frustrated.
The trooper has a really bad starting behaviour (cold and warm). When I start the engine the motor runs only for 1-2 seconds then dies again. Giving him some gaspedal hits nearly has no effect (even if I push gently or full throttle). It seems he is not getting enough fuel if you ask me.
After 4-5 starting procedures he mostly comes to life (often followed by backfiring). If he is finally running the engine behaviour seems to be quite normal (just sometime a small shaking)... If I "play" with the throttle he's showing sometimes smaller backfiring. If I turn the engine off I am getting the same behaviour as before.
Until now I already replaced the spark plugs, fuel filter, air filter, checked the whole air system, cleaned up the throttle valve, replaced 2 year old fuel, replaced all vacuum hoses in the engine bay, checked and corrected valve clearances and I had put fuel injector cleaning substrat into new fuel but nothing had solved the problem.
Did someone of you maybe heard or had similar problems?
My last left-over assumptions are fuel injectors, fuel pump, bad ignition timing or a faulty ignition cable / dirty distributor cap...
What do you think? I really hope to find some good answers here because I have so many open project-ideas I would love to follow.
Thanks in advance!
ghost
Thanks in advance!
ghost
