1 - 6 of 6 Posts
I've got a good 3.2 dohc trooper engine, I'm looking at a rodeo with a bad 3.2 engine. Does anyone know if the eng from the troop will work in the rodeo?
Thanks
Thanks
WHAT YEAR ARE THE ENG,S AND WHAT YEAR IS THE RODEO.
94 trooper and 93 rodeo
thanks
thanks
YES THE 94 3.2 ENG WILL BOLT RIGHT IN TO THE RODEO, WHAT YOU NEED TO DO IS REMOVE THE COMPLETE INTAKE MANIFOLD ASSY, AND USE THAT AND THE RODEO WIRING HARNESS AND INJ ,S ON THE DOHC ENG , USE THE RODE IGN COILS AND RE ROUTE THE IGN WIRES TO FIT ON THE DOHC, , ALL SO THE EGR PIPE WHERE IT BOLTS TO THE DOHC MANIFOLD WILL HAVE TO BE RE SHAPED A LITTLE BIT , OTHER WISE EVERYTHING ELSE WILL BOLT RIGHT UP. WHAT YOU ARE BASICALLY DOING IS MAKING A DOHC ENG WITH AN SOHC INTAKE SYSTEM, AND IT THE RODEO IT RUNS PRETTY STOUT .
that's what I was hoping for, thanks
Also check hood clearance after install you may have to dimple under side of hood not bad but it will rub about 2in circle
1 - 6 of 6 Posts
