The body mounts for the 1994 Trooper are no longer being made by anybody. Does anyone know of something else that will work?
Have you checked with Jlemond on this site for OEM mounts?
Sounds like a good excuse for a body lift to me :wink:
Nope it's the rubber bushings that are shot
That's a fairly generic part, isn't it?
Trooper, Frontera, Rodeo, Passport are all the same.
Installed these 9.4102 Universal Mount on front and under cab. (the first 4 sets of bushings) Had to make a 3" flat washer to support between the lift block and new bushings (the lift block is slightly larger than the flat washers that came with the new bushings), also moved up to 1/2" hardware on the first 3 sets of bushings. Also added a thick rubber O ring between the two bushings to help center the bushing in the frame hole. This bushing has about 1/16" to 1/8" smaller shoulder that goes through the frame. However the over all bushing width is wider than the factory ones. I did not replaced the last two sets of bushing yet because I will have to make a special plate to adapt the universal body mounts.
