I have trooper 98 s with 63k.
I just did my 60k service including changing all the fluid, driving belts, filter, etc.
But there is two things I couldn't done myself:
The valve adjustment and repack front wheel Bearing.
My question his?
Is it necessary to repack the front wheel bearing every 60k or just if you driving in bad conditions (deep water, off road)?
I have some knocking noise from the left back side of the engine is it cause of valve that need to be adjust? Also the engine doesn't run as smooth as it should be.
Thanks tomer
My question his?
Thanks tomer
