1 - 2 of 2 Posts
· Registered
Can an automatic transmission from a 99 Trooper with TOD, be put in a 98 Trooper to replace the automatic transmission.
Would the drive shaft on the 98 Trooper stay the same? The TOD system would not be installed on the 98 Trooper, just the 99 Trooper Transmission.
thanks,
Tim
· Registered
The transmission can be interchanged with no issue. Just take the TOD transfer case off the donor trans and put the "normal" one from your current trans on and you won't have to do any driveshaft swapping
1 - 2 of 2 Posts
