Well, fix one problem, another one showes up.
I installed the new alternator Saturday morning, everythings working great. Later that day, I start noticing a new shudder. Basiclly, I get a vibration, more through the steering wheel than shifter, but everything shakes. It happens when I'm maintaining speed at low RPM's. If I coast, and apply a little gas, the RPM's drop by about 200 and I get the shudder. It will last as long as I gently apply gas. If I let off the gas, it goes away, and the RPM's go back up. If I give it enough gas to down shift, the RPM's go up and all is normal. It does it at all your normal crusing speeds, 30-35, 45-50, and 65-70. One sure fire way to get it to kick in is to simply let it idle straight and flat.
The engine seems to be running smooth. It dosen't shake unless it's in gear. I figure I'll change the transmission fluid tomorrow. The level is fine. It's been a while, but it's not overdue.
Does this shound like the beginning of the tranny starting to slip? Any suggestions?
Thanks,
Andre
Thanks,
Andre
