pbrooke said:
Would Jwood's old transfer case from his Amigo work in my Trooper?
I have an automatic, 4x4 TOD.
He does not have TOD.
Thanks for your help.
YOU MAY HAVE TO CHANGE THE REAR TRNS CASE ADAPTER , BUT THEY ARE EASY TO FIND, OTHER WISE IT WILL FIT THE OUTPUT SHAFT AND YOU WILL HAVE TO CHANGE THE DRIVE S TODS FLANGES ARE MUCH BIGGER AND WILL HAVE TO DO SOME WIRING , HIS HAS THE SHIFT ON THE FLY MOTOR ON BACK, SHIFT HANDLE IS IN THE SAME ,LOCATION, ABOTU THE ONLY THING THAT MAY BE DIF IS THE ADAPTER PIECE ON THE BACK OF THE TRANS , YOU MAY NEED ONE FOR A REG T/CASE
