1 - 4 of 4 Posts
Does anyone have advice or can point me to a thread about moving the trans crossmember up about 10" for a manual transmission? Right where it needs to go there are these blocky jack points sticking down.
I figure I can cut off the blocks and fab a mounting bracket for the existing crossmember, or maybe weld a bracket along the inside of these blocks, then build a new crossmember out of some 3/4 or 1" square tubing. I'm new to fabricating and I'm sure I'm overlooking a simple solution.
I greatly appreciate it.
Automotive tire Tree Motor vehicle Tints and shades Rolling
And I will state preemptively that my Aisin trans began overheating often, I tried a synthetic ATF flush, and it burned up the fluid pretty quickly. Then it would occasionally take a few long moments to move after being put in gear. I was looking for an excuse to do the swap so that was enough for me.
Thanks for the feedback.
Lorenzo, I hope to see what you come up with.
I also have the crossmember from the manual donor vehicle, and was thinking I could fab some mounts for it, I would have to cut off the jack points, but it would save having to cut off the stock mounting brackets.
I made a rough mock-up. I think I need to shorten the right vertical piece because it'll hit the arm the supports the body, and add a couple more vertical pieces on the top and bottom to tie it all together.
1 - 4 of 4 Posts
