Hi all!
I've read several messages about the transmission range/mode switch. I followed the advice that most have given - clean out the gunk. I tried and I still have the same problem - transmission slipping. Do I need to replace the switch? Or is it a different problem? The switch do look pretty bad and maybe burned.
I've also changed the thermostat which is a pain. That doesn't seem to fix the problem.
How much do the transmission mode switch cost and is there a store online that you can recommend or just buy from dealer?
Thank you.
Thank you.
