I been fighting to save this 2001 Isuzu Rodeo 3.2 2wd sport tranny with flushes and lucas and a prayer and it seemed to come around(Lot less slipping) unless i was in the city and stop and go it seemed to act up occassionaly. So i noticed it had an external radiator cooler and it was small and it made me think that its been over heating doing stop and go and hot days. I got this car as is but been diving in on various issues and kept thinking the transmission is low or hot or both. Well one things for sure that small exterior tranny cooler aint cutting the mustard so i decided to trace all the lines out from the tranny and found out they capped the2 radiator in/out and was only using the small exterior cooler. OK here in lies the issues. I un capped the radiator lines for the tranny to see what would come out and it was tranny fluid. Pretty dark but some red in it. Like a table spoon worth. So to me that means there SHOULDn't be an issue of a bad radiator to mix the coolant with ATF to make the MOD(Milk shake of death). If i run atf through the radiator now and fill it and get it pressurized and have the return capped so not to go back to tranny and it holds do you guys think its worth to try it? I dont know why they did this in the first place and the radiator looks "Newer". Diagram included as how I found it. Thanks ahead of time guys
