1 - 10 of 10 Posts
I have an opportunity to pull the front brakes from a '93 Rodeo, for my "BIG BRAKE" upgrade. I'm also considering pulling the brake booster and master cylinder. Since the Rodeo is in a remote spot I won't be able to make trips back to my garage for some tool I may have forgotten.
So, any suggestions as to what tools are special, or that I absolutely need, to pull rotors, calipers, booster, and master cylinder?
Thanks in advance for the help.
When I pulled the rotors from my Rodeo, I needed 2 special tools that I didn't have:
Impact driver. when you get the hubs off (either auto or manual) there's that flat round piece with holes. It's held on by 3 fine screws. these suckers were really tough to get out. I used the impact driver to loosen them. Basically, it's a screwdriver you whack with a hammer. It was like $20 or so, I don't remember.
Here's a photo showing the round piece (from when I was having problems installing manual hubs due to spline damage):
Isuzu hub tool. I happen to have an 'official' Isuzu hub nut tool, but the job can be done without it. Just tap the holes with a punch or screwdriver and hit both sides and it will unscrew. It's the part you use the fish scale for, so it's not on there super tight.
Good luck.
PM sent
GB :)
THIS!! Those screws like to strip out and the impact driver will break them lose without stripping the heads. Either this or take a cordless drill and some bits just in case.
If you want to be fully prepared,bring every tool you can fit in whatever vehicle you go to the rodeo with. I do have to ask,why are you working on it in a remote location? Is it stuck there?
Thank you for that info Mr. Tatohead. After I posted I did a search and came up with a couple of threads mentioning the tool and the problematic screws. The moral? Search before asking, as it probably has already been talked about at some point.
I found a place to order the "special" tool but will take a drift and hammer with me if I don't get the tool before I do the deed. I also have a hand impact tool and with take that as well.
Ouch on those splines. I presume you got it worked out okay?
Good luck.
Thanks for the reply and info, Mr. Catfuzz.
Thanks for the reply.
Remote is the wrong word, and no it's not stuck, it's in a pick and pull yard. It's far enough away from my house that I want to be prepared. It's the Boy Scout in me. I usually bring more tools than I need, but in this case if any special tools were required I wanted to know in advance so I didn't forget them. In spite of the fact I take way more tools than I need, I invariably forget something important. Know what I mean?
1 - 10 of 10 Posts
