My TOD Check light went off first time a few weeks ago. Then the ABS light went off as well. Ends up I had a tire going flat in the rear. My guess is that the ABS sensors saw the rotation difference and threw the lights. Once I fixed the tire it never came back. BTW I was in 2wd when it threw the lights.
If you did have an real error, it will def. have something to do with the 4wd system. Probably the most common issue might be the front axle disconnect system.
Good Luck,
Con
