Hey all,
Thought I'd open a thread on my "build". The past 9 months of owning this Trooper I'd been preoccupied with fixing/servicing a few things per week. Now that I have it running reliably and with few repairs left I figured I can open a thread dedicated to documenting what I've done so far and the future repairs/mods.
The Trooper
"Tippy" (you can thank Consumer Reports for that nicnkame): 1993 Trooper LS, 4x4, limited slip rear, DOHC 3.2L, automatic, 240k kilometers/150k miles on the odometer
This Trooper was owned by my parents since new. My Dad bought it because he could fit a full size sheet of plywood in the back, and "the doors sound solid when you close them" - he had also looked at monteros and 4runners. He now owns a Toyota Tundra (pic below of his tundra towing Tippy on a flatbed the day we picked it up).
My Dad sold Tippy to a family friend for $500 at a discount in 2011 and it was re-obtained by me in Summer 2019 for $0.
Born in 1997, my ride home from the hospital was in this Trooper. Many of my early childhood memories are riding in this trooper. When I first cracked open the doors of this truck after it had been sitting for 3 years, the smell actually gave me some intense nostalgia and brought me back to being a kid. Weird.
Anyway, needless to say the trooper has high sentimental value to me, and as I do have a bit of disposable income, I've since started putting some decent money into it this past half year or so. Additionally, owning this trooper has been some motivation for me to learn mechanics and how to save money working on my own vehicle.
Done so far:
Brakes
This is why it was parked. The ABS system was wonky so I pulled the fuse.
The calipers were in bad shape - I opted for rebuilt ones all around.
Transmission maintenance
(1)Vehicle was found with smelly, partially burnt fluid. My dad towed a larger size box trailer with this quite a bit, and didn't change the ATF as much as he should have. A cooler was never installed despite this coming with a tow package. What was Isuzu thinking providing a heavy duty radiator but no trans cooler with the tow package?
(2)Initial 2-3 drain and fills with generic parts store brand Dex III. No drain plug, siphoned fluid out of the dipstick overnight a couple times before dropping the pan
(3)Filter change - was able to do this without dropping the exhaust. could not remove the pan fully but still had access to clean it out and remove the filter.
(4)Clean and inspect magnet & transmission pan - relatively little debris. quite clean, for having not been serviced in multiple decades if ever.
(5)install auxiliary cooler - Hayden 2657 run pre-radiator to limit overcooling in cold weather. It's below zero for the majority of the year here.
(6)Flushed 10 quarts of fluid through the cooler lines, replacing with generic parts store brand Dex/Merc.
(7)Trans was still surging between 2nd and 3rd gear. Planetisuzoo user Oro reccomended using Seafoam Trans Tune to clean up buildup. Within 100 miles of driving, the shift surging issue was completely gone. In my case the issues with shifting were caused by dirty fluid and varnish/gunk buildup, and luckily the transmission seems to be mechanically sound.
(8) Fluid still had an odd smell, and ~200 miles later I flushed another 10 quarts through, this time Lubegard synthetic Dexron (also a reccomendation from Oro).
(9) Replaced throttle position sensor - 1-2 hard shift greatly reduced, but still more jolty than 2-3 and 3-4
Timing belt and water pump
Took me about 9 hours total. Followed my OE workshop manual and a writeup for the SOHC. Luckily made no mistakes as I am a novice and could have screwed this up.
Replaced the water pump, tensioner(s), idlers, fan clutch, all v-belts. I didn't really enjoy doing this but getting it done is satisfying.
Cooling system
As mentioned above, replaced water pump.
Replaced rad hoses and lines to the oil cooler - original rubber
Replaced fan clutch
Replaced the radiator - out with the original Tokyo Radiator, in with the shiny new Spectra Premium
Rear Suspension
New coils - the old ones were really fatigued from lots of hours towing. Replaced with Moog cc784, pigtail ends cut off, provides 1.5-2" lift
New shocks - KYB gas-a-just
Fresh LSD gear oil
New poly rear sway bar bushings from Siberian Bushing
Front end
The previous owner, a family friend, had the wheel come off on the highway and I discovered the ball joint castle nut had been completely ground off down to the knuckle and basically welded in place - see pic below. Had to get a junkyard knuckle/hub/bearing assembly
New front u-joints
Torsion bar crank to match the rear lift
Auto hubs BS - the snap ring was popped out when I got it and this has happened to me on the trail since then
Ball joints on passenger side
Front wheel bearing preload adjust and alignment
Exhaust repairs
Leaking flex pipe replaced
Restricted catalytic converter replaced with a resonator
EGR passage in throttle body was clogged with carbon deposits
New Tires
Decided to stick with stock size. Kumho Road ventures - all season, all terrain, winter rated. I've had them for 4 months, so far they're great.
miscellaneous
All 3 igntion coils were split wide open at the bottom - new ones have fixed my misfire at idle
New spark plugs
New PVC valve
Fuel filter
Front diff and tcase fluid
All new vacuum lines
Throttle body clean
Fuel injector cleaner and seafoam
...and many other things that I'm forgetting about!
STILL LEFT TO DO
recent multi-item service performed! Tippy is running better than she has in a long time (06/11/2020)
-remove freeze plug under the DOHC plaque, allowing access to clean out the EGR port fully
-Valve cover gaskets & the "while you're in there" items:
-Repack wheel bearings
-Cv boots, just starting to crack. I think these are the originals
-Bushings:Sway bars
Cosmetics: Quarter panel wheelwell rust repair & replace missing fog light.Paint skid plates.
I'll leave you with a photo of Tippy stuck on the trail because the snap rings in my auto hubs came out:
The Trooper
Done so far:
Brakes
Cooling system
Replaced fan clutch
Rear Suspension
Fresh LSD gear oil
Front end
New front u-joints
Exhaust repairs
New Tires
miscellaneous
New spark plugs
New PVC valve
Fuel filter
Throttle body clean
STILL LEFT TO DO
- spark plug tube seals[/*]
- inspect wear on cam chain tensioners[/*]
- replace heater hoses and coolant bypass hoses [/*]
- clean + strip and paint the heavily oxidized upper intake[/*]
- replace coolant crossover pipe o-rings[/*]
- replace coolant temp sensors[/*]
- replace fuel pressure regulator[/*]
- fuel injector o-rings[/*]
- test and or clean fuel injectors[/*]
-Bushings:
