1 - 2 of 2 Posts
· Registered
HI,
I have recently puchased a 1999 Rodeo with V6 engine.
I need to change the timing belt and the only maintenance manual I could find locally is for for 1989-1997.
Does anyone know if the procedure for changing the belt is similiar enough, that the old manual would be adequate for doing the job?
Thanks :!:
TW
· Registered
I would keep trying to find a book, or talk to somebody that has done one. The '97 is a SOHC, whereas the '98 is a DOHC. I think there are some differences in how you have to line everything up. If there plenty of marks, it still should not be that bad. When i changed the one on my '96 it was difficult to turn the cam gears and crank pulley to get stuff lined up, but the overall process was not that difficult. I would definately recommend changing the water pump, and the belt tensioner. I didn't change the pump, and not quite a year later the new belt wore out my old pump. :roll:
Adam
1 - 2 of 2 Posts
