1. Do you think it is out of stock position, and want to move it back to try to cure rough idle, or starting probs?
2. Or, do you want to move the position up a bit to take advantage of advanced timing?
If it is #1, you'll need to find the stock voltage level (should be in the Helms), hook up your volt-meter, and slightly turn till you get there.
If it is #2, check stock voltage in the Helms, and bump it up 10% at a time, till you get rough idle, or pinging, then back it off till it goes away. Then test drive, and check for smooth throttle response. If it feels rough, back off another 5%. - Repeat as needed.
This proceedure will work on any POT-type TPS, which I would assume yours is.
The Helms should have the proceedure too.
