I've never heard of one myself, but I really dont know all that much.....
There have been people that have replaced the whole thing because of that particular problem, and it cured their woes, so you might have to go in that direction.
my truck idles at around 2 grand right now, and sometimes it will slowly idle higher and higher, something is sticking, but i'm not sure what exactly..
I'll try cleaning it. I bought gumout throttle body cleaner. It says to use the whole friggin bottle! I'm positive it's not the cable because it has full travel with a bit of slack. Seems like the linkage to the lower throttle valve is sticking. How much freeplay should there be in between the upper valve and the lower one? There is a stop screw, is it wise to mess with that? Could it be out of sync? How do I adjust this sucker?
Well I can tell you it's a PITA to get that thing on and off. It woudln't be that bad if it didn't have two vaccum lines and two coolant lines going to the bottom side of it.
Geez they were downright impossible to get hooked back up.
Anyway the adjustment you'd be looking for is the no throttle applied and butterfly just barely open. You should be able to hold it up and just barely see a bit of light through it.
I'd also look at the throttle switch. It could be out of adjustment.
BTW- 500 buck! That's more than what I paid for the truck. It had the typical head problems. After market head installed for 1000. Runs great. Passed CA smog without problems.
Tell me more about the coolant lines attached to the throttle body/
There are two hoses about the size of a nomal sharpie marker on the very bottom of the throttle body. Other thant hey are very difficult to remove in such a tight place and maybe that was due to someone cut them off the first time, I don't know.
All I know is that there wasn't enough slack to get the throttle body up where you could work on getting the hoses on and off.
I read an old tthread, and in it you said you had found a throttle body for nothing near what the dealer was asking for it, where was it that you bought it from and how much was it?
