I drive a 2000 Rodeo v6 auto transmission.
Looking back and forward I will never buy a vehicle with an automatic transmission. My last vehicle, a dodge caravan went through 3 transmission rebuilds. Now one rebuild with the Rodeo that could have been totally avoided. Changing a clutch is a lot cheaper than rebuilding the whole tranny.
A standard transmission will get more power out of the engine and more control of your fuel economy.
I sloppily spoke of Isuzu's negatives so lets talk about the positives.
1) Outside of replacing the starter motor, this is a very easy to work on vehicle
2) Turning this vehicle into a capable off road vehicle can be done easily and cheaply. Changing to old man emu springs in the back and cranking the front torsion bars will get you 2 to 3 in lift.
3) Low stress engine can haul ***. This vehicle (V6) is set up with low gearing in order to be able to go off roading and towing. I will not win any quarter mile races without a supercharger, but it will last and take a load.
(You must watch your oil levels and oil cleanliness. Filters must be changed regularly and flush must be done on schedule.)
4) Both the Rodeo and Trooper are good looking vehicles (Period)
I am not interested in convincing or disuading you into buying Isuzu. I like it. If they would let the 3.0 turbo diesel into N. America I would be beating people up to get to the front of the line
Once you decide to buy an Isuzu
1)look up the the faq site and make a maintenance plan.
2)Have the dealer or your mechanic do a 30 k maintenance check up before you park it in your driveway
3)Buy a helms or Haynes manual. Someone hear will email you a factory manual for free.
4) Check for the location of your nearest Isuzu dealer. You only want to take it to a dealer if it needs to be towed away. St. Charles Isuzu (St. Louis) will sell and ship any part at affordable prices almost anywhere in the United States and Canada
This should be done with every brand vehicle not just Isuzu. A lot of other brands are set up so you cannot maintain your own vehicle. At least with Isuzu you can do 95 percent of the vehicle repairs yourself.
Again I don't want to feed my ego buy convincing you to buy an Isuzu. If you are going to use it only as a daily driver, the Santa fe has a good rep.
If you are going to tow a boat or trailer, give it a lift and go into the bush, Isuzu is affordable and strong.
Final advice- SUV's and 4 cyl. don't mix. If I saw you writing a cheque for one I would give you a flying drop kick, pound you to the ground tear up your cheque then force you to thank me, then make you buy me dinner.
John
