Let’s just call it ‘research’ for now and leave it at that, but I have a few rather specific interrelated questions (several of which are going to make it sound like I’m a complete newbie â€" but honestly, as far as the 2nd gen Troopers are concerned, I basically am) --- Anyway, here goes:
The 2nd gens came with -38mm offset wheels, right?
Has anyone ever run a set of Zero offset wheels and 265/75-R16s?
If so, did they rub? / and either way, how much lift do you have?
A 1997 model would have the 3.2 DOHC, right?
On the same vehicle ^ with an automatic transmission, it would have the shift lever-actuated T-case â€" not the push-button variety, right?
And that would be the divorced T-case (removable from the transmission), wouldn’t it?
Also on the same vehicle:
It would have 4.56 gearing, correct?
Aside from a/c, pw, pdl, cc, and tilt… what else came with the LS package that year?
When lifted, a 2nd gen Trooper doesn’t suffer from the ‘upper link/ gas tank clearance problem’, like the 2nd gen Rodeos, does it?
[* and Drum-Roll please… *]
If you found a 1997 Isuzu Trooper LS listed for sale at $2400.00…
What are the first things you’d be checking -or- suspecting might be wrong with it?
TIA!
Cheers!
Smiley
TIA!
Cheers!
Smiley
