i have always wanted to mount my high lift to the back of my spare - but i am not a welder and struggled to figure out a way to make one out of pieces.
I also needed to be able to take it all off reasonably easily when i got back to the city (aka reality)
then it came to me and i ran to the hardware store, and for 15 bucks I made one
went to hardware store and bought this bunch of goodies:
(i made that big so you can see the scale - I ain't giving a list here folks)
looked at my spare and took off the bottom bolt holding the spare on
took the flat piece of steel and drilled two holes 5 1/2 " apart at the centers (they are where the drill bits are) holes are about 1/2" wide
next i drilled a hole on the spare holder (tire still on) through the top hole on the rim (about 1/2" wide)
next I fed the long bolts with washers from the inside of the holder (you must squeeze your hand back there thinking it is stuck forever)
from there ,slide two of the long nuts over each bolt (each nut is 1 1/2" long = 3" spacing)
the steel piece should slide right over the bolt ends and you screw the nut tight to hold everything together
from there, you just use the two smaller bolts and nuts to hold your high lift jack to the mount and tighten the hell out of everything:
VOILA! A no welding, high lift jack mount that seems to be really strong, and looks good too!
