I noted on another thread a discussion on changing the Coolant Sending unit and the Temp Gauge sending unit..
Not wanting to hijack that thread I figured I should post my own inquiry..
I touched on this a few months ago on another thread RE:My Sons Rodeo but at that time the tread was getting kinda long and unfortunately I didn't get enough info to clearly understand the repair/replacement of that part..
Did find this link posted by another member:
http://forum.planetisuzoo.com/viewtopic.php?t=15158
My Q is this, is the Temp Gauge Sender the "SINGLE" Wire sending unit to the LEFT of the Coolant Sender (Circled in RED in that links PIC)?
Also I see the link is based on a Tropper instead of the 3.2 V6 in the 95 Rodeo..
As such is the replacement procedure the same on the RODEO and is there anything specifically diff in doing this if the vehicle is 2WD as opposed to 4WD?
TIA, MIKE
TIA, MIKE
