dumb question guys....After reading this article can I simply cut the blue wire to disengage TOD and have the 50/50 power split?
It's perfect for you. It will shut off the 15% to the front in a VX. Then add some manual hubs and the axle won't spin at all. Even with just the disconnect you'll loose that noise. Search on vx.info I posted pics of my TOD disconnect and 50/50 mod in my VX there.phines said:Hey guys,
When you shut off the TOD this way, does it completely disengage the front drive shaft? Or does it still get that ~15% power?
My front diff is a little noisy so I'd like to cut power to it for everyday driving and save the front diff for off-road...
