1 - 6 of 6 Posts
· Registered
1986 Isuzu Trooper II
Hi there everybody. Sriving an 86 trooper diesel 2 door. My tachometer doesnt move. I thought it has a connection somewhere at the injection pump (or am I wrong?) but couldnt find an obvious terminal where a wire is attached to.
Is the tach realy connected to the i kection pump ? Of not, ca. amybody point out to me where please 😊😊
Thanks
Les
· Registered
The tach is connected to the injection pump. There is a two wire clip near the front of the IP with a black connector and black wires. The black/yellow single wire with clear clip on the back of the IP opens the fuel solenoid when the key is in the run position
· Registered
These are usually really dependable. If it's not working, it's most likely a bad electrical connection somewhere, or a wire that has worn and shorted against something metal.
· Registered
Thanks guys will explore. There doesnt seem to be a terminal or a wire that was once upon a time connected down there. But ill check. I actually dont know what im looking for cos the IP never had it. So, if there coupd be a photo of it so ill know how it looks like ....... ??? Kindly send 😊😊
1 - 6 of 6 Posts
