Folks,
The current "challenge" is removal of 2 x 22mm head bolts on the Trooper's caliper bracket. The caliper bracket(holding the caliper sliding bits) needs to come off in order to release the disc (which is well due for replacement).
Heat and 100ft/lbs++ makes no impact. The area has been sprayed with penetrating fluid on several occasions over several days. The "blind end" is hidden behind the disc, so can't be accessed very easily.
The next move is use of an impact driver. I recall using one in the seventies, to not much effect. Has anyone used one and can recommend one? After that, it may be time to resort, reluctantly to a large bar. No, not one with beer taps on it.
Air impact wrench at local tyre depot? Any other clues welcome. Any danger of breaking anything with brute (bruce?) force
Cheers
rg
"A Pom with aplomb"
Cheers
rg
"A Pom with aplomb"
