1 - 6 of 6 Posts
I lost my measurements. Can someone measure a second generation stock trooper from the top of the wheel lip to the bottom of the fender?
Thanks
Thanks
they will vary due to sagging suspension components 8) recon
Maybe these will help...
Stock 2nd gen is 1850mm (72.83in) tall at the roof. Compare that to how tall your body is now. With the difference in tire size vs stock you can figure out how much lift you have, if that's what you're trying to do.
I need to do the same thing for my first generation trooper. Is there a diagram like that for earlier troopers?
Thanks
get the factory service manual. It should have a procedure for adjusting and measuring ride height. At least the honda passport manual has such a procedure.
1 - 6 of 6 Posts
