1 - 2 of 2 Posts
so it only has happened twice, when it was cold in the morning. my speedometer "sticks" if im stopped it will say im doing 55mph or whatever. doing 40mph (im assuming) it says im over 100mph. if i hit the gauge enough times, it settles back down to zero (this is when im stopped) do i need a new gauge, or is it the cable or...?
That is probly going to be the gauge itself sticking, if you are decent with wrenching you can carefully take apart the cluster and lube the pin and moving parts that operate the gauge with a small amount of spray lube and see if it cures it.
1 - 2 of 2 Posts
