1 - 2 of 2 Posts
99 amigo v6 will only start in neutral. alarm has been acting up also and going off on its own. I heard a relay spazing out near the fuse box turns out the rest tailgate pin switch was bad contact and kicking on the dome light periodiclly. Now. We are having a no start issue.. wired.. neutral only.. don't know if the problems are related.. need sugestions. Neutral safety switch?
I'm assuming it's an auto tranny. There's going to be a switch that tells it when it's in park that has gone bad. The neutral safety switch is (apparently) working, or it wouldn't start in neutral either :)
I don't know enough about that vehicle to tell you where it is or how to defeat it, but I usually just cut off the plug and tie the two wires together when I'm doing that sort of thing on my own vehicles. It'll start in any gear after you do that, but if you're not a moron, that shouldn't be a problem. The alternative is replacing the switch...some are cheap, some are unreasonably expensive, your call.
1 - 2 of 2 Posts
