1 - 8 of 8 Posts
I've had an 1988 trooper for about a year now with little to no problems. Recently my trooper hasn't wanted to start up, it turns over with that RRRRRRR sound but doesn't fire up? I've replaced the fuel filter, spark plugs, distributor wires and the fuel relay. I can hear my fuel pump working as well.
After doing some tests on everything I've noticed that I'm not getting any spark. Could it be my ignition coil? Maybe my igniter? If anyone could help I'd appreciate it.
Could be. What test did you perform to determine no spark?
I tested the spark from the distributor cap and then check the spark coming out of the ignition coil. I used a light tester.
Is your rig fi ??? If you have a book you can find the resister test on the coil itself. I'm not sure if theres a test for the pickup in the dist. Most likely there's a given amount of resistance as well. It could be either one so test carefully. Sucks to throw money at it...
The distributor has two basic jobs.
A. Generates the low voltage trigger signal to the ECM.
B. Routes the high voltage pulse from Coil to the correct spark plug via the cap and rotor.
Fuel injection... It's an 88 I wasn't sure if it was carbed or not. That would change the properties of the dist. a little I think. Where able to test the coil ??
Check your engine relay under the fusebox..
1 - 8 of 8 Posts
