Usually, upon startup, when I go to pull away from the curb, the engine stumbles a little and nearly stalls.
I know that I need to replace the gasket between the throttle body and intake plenum, but wouldn't that cause a surging idle and not what seems to be an air starvation problem?
I just replaced the fuel filter, air filter (K&N) was just recharged, intake was cleaned out thoroughly when the valvecover gaskets were replaced, EGR was replaced and tube cleaned, O2 sensor has less than 5k on it, and I also recently did a complete seafoam run-though (engine, oil, and fuel) to clean out everything.
Also, if I am sitting still after startup, and I rev the engine to around 3500-4k, and let off, it will also stumble. I have gotten it to stall out completely once because of this.
Would anyone know what might be causing this problem? Fuel pressure regulator? Fuel pump?
