Experience
Ok this is what I was referring too. When driving around the city around 40-45 mph I am wondering if if would be more EFFICIENT to just stay in 4th instead of 5th. I always thought it was bad for an engine to cruise at lower RPM's then it was intended too. Thanks for all the non smart *** replies.squatch said:Simple if the engine is lugging the gear is too high. If the engine is screaming the gear is too low. The idea is to stay in the comfortable power band of the engine most times. For fuel economy stay in as high a gear as you can without lugging the engine. Need more power down shift. The best way to learn to drive your stick is to install a vacuum gauge in the dash. This will tell you exactly how hard you are working the engine. Vacuum gauge is also the best way to judge driving for fuel economy.
I would say 4th, because 5th might lug the engine. if you're just cruising, I'd try to keep the rpm's around 2k-2500.jwood1016 said:Ok this is what I was referring too. When driving around the city around 40-45 mph I am wondering if if would be more EFFICIENT to just stay in 4th instead of 5th. I always thought it was bad for an engine to cruise at lower RPM's then it was intended too. Thanks for all the non smart a-- replies.squatch said:Simple if the engine is lugging the gear is too high. If the engine is screaming the gear is too low. The idea is to stay in the comfortable power band of the engine most times. For fuel economy stay in as high a gear as you can without lugging the engine. Need more power down shift. The best way to learn to drive your stick is to install a vacuum gauge in the dash. This will tell you exactly how hard you are working the engine. Vacuum gauge is also the best way to judge driving for fuel economy.
JOHN DO WHAT MARK SAID , GET YOU A VACC GAUGE AND SET IT WHERE YOU CAN SEE IT AND RIVE BY WHAT IT IS TELLING YOU , IT WILL BASICALLY TELL YOU WHAT YOUR THROTTLE OPENING IS AT ANY SPEED OR GEAR POSITION, AND YOU WANT TO DRIVE AT THE HIGHEST VACC READING YOU CAN FOR THE MOST MPG, IN OTHER WORDS AT 45 MPH JUST SAY YOU ARE READIGN 14 IN VACC , IN 5TH GEAR MAINTAIN THAT SPEED AND GO TO 4 RTH G GEAR IF THE MANIFOLD VACC INCREASE TO 18 IN OR GOES UP ANY YOU NEED TO BE IN THAT GEAR AT THAT SPEED , ANY TIME YOU SHIFT TO A HIGHER GEAR AND THE MANIFOLD VACC DROPS THE ENG IS WORKING HARDER THE ROM AT THE HI MANIFOLD VACC HAS LITTLE TO DO WITH FUEL MILEAGE , SINCE THE HIGHER THE READING THE MORE CLOSED THE THROTTLE BLADES ARE WHICH MEANS LESS AIR IN THE ENG AND LESS FUEL, I PROMISE YOU ,YOU WILL CHANGE YOU DRIVING HABITS WITH THE VACC GAUGEjwood1016 said:Ok this is what I was referring too. When driving around the city around 40-45 mph I am wondering if if would be more EFFICIENT to just stay in 4th instead of 5th. I always thought it was bad for an engine to cruise at lower RPM's then it was intended too. Thanks for all the non smart a-- replies.squatch said:Simple if the engine is lugging the gear is too high. If the engine is screaming the gear is too low. The idea is to stay in the comfortable power band of the engine most times. For fuel economy stay in as high a gear as you can without lugging the engine. Need more power down shift. The best way to learn to drive your stick is to install a vacuum gauge in the dash. This will tell you exactly how hard you are working the engine. Vacuum gauge is also the best way to judge driving for fuel economy.
