I'm a novice trying to learn, so please be gentle. I have a 1997 24-valve 3.2L SOHC Trooper, and I'm curious about the "SOHC" part. Looking at the engine, the "V" part of the V-6 is obvious, and I can clearly see the 2 banks of 3 cylinders each. The timing belt cover is clearly shaped like a "V" also. It just seems to me that there would be a camshaft over the top of each of the two banks of cylinders and that this would be called DOHC. Does DOHC mean two camshafts in each bank, and SOHC mean one camshaft in each bank? Maybe there's a camshaft for the exhaust valves and another for the intake valves for DOHC and just one camshaft for all valves in each bank with SOHC. You can see that I know just enough to be very dangerous. Thanks for your help.
ph
ph
