Last year I decided to have my A/C checked (99 Amigo) after going 2 summers in the Northeast without (no big deal).
The mechanic I brought it to charged the system and put a tracer fluid in for me to come back at a later date. He said there was probably a leak.
Well, the charge lasted about a month and the A/C was working with a moderate coolness coming out.
This spring I checked and the system doesn't turn on. I opening the cap to one of the valves on the system and there was compression between the two (hiss sound when I removed the cap. I didn't touch the valve at all.) No tracer fluid anywhere except at the cap.
I brought it back to the mechanic and he mentioned the leak probably was coming from a component inside my dash since he did not find any tracer fluid. Total estimate $1,200.
Questions:
Why would there be compression between the protective cap and the valve?
What could be done for (what I perceived... as the charge lasted almost a month) a slow leak?
Any simple test I could perform? and...
Where would be a good place to bring this problem (another mechanic, dealer (yikes), some specialty shop???)
Any advice much appreciated. -MaKai1
Questions:
