hadji_85, I can't wait to see what it looks like. I think people on this board are very friendly and helpfull. I've gotten a lot out of it, like the article on changing your fuel send unit...something that is apparently a common problem with rodeos like mine.
I know nothing about lowering or raising an SUV, but just to lend some support for the lowering camp, most of the lifters are going for better off road utility...but no matter how high you lift your truck there's always that rear diff hanging about 5 inches off the ground. I bet there are mini vans with better ground clearance than an average truck. I often see these pickup trucks way off the ground, but right there in back is that rear diff ready to scrape something. A raised SUV looks cool, but physically and logically it seems moronic to me. You're way high up in the air, but a very integral part of the drive train is way low to ground, and as far from a wheel as it can possibly get, exactly in the middle.
Why isn't the rear diff gear box offset to the side a little? Why isn't there some type of skid plat under it? That would take advantage of a wheel's protection, ie, the wheel would be touching the rock that might scrape the gear box. There's even an article somewhere that describes how to change the rear diff fluid, and mentions pounding the cover flat after scraping it on a rock. Obviously it's because that happens a lot, and it makes sense.
I think the rule of thumb for lift bragging rights should be the distance between the ground and the lowest drive train component (besides tires).
Taylor
