Thinking of doing a mild SAS on my ‘91 Trooper. I am going tomorrow to look at a Wagoner front axle, but don’t know yet what year it is from (or even if it is a 44). The same person also has a number of Scout II’s. Has anyone used a D44 out of one of those for a first gen SAS? I plan to stay spring under axle and don’t want to get into narrowing a housing and getting custom axle shafts.
Thanks,
Patrick
Super Moderator
I believe Scouts are 5 lug. Also I think they’re wider than a Wagoneer. Not sure on the width.
The five lug part doesn’t matter as you can swap the necessary parts for 6 lug. As far as I have found online the Scout 44 is actually 3/4” narrower WMS to WMS than the wagoner. My bigger concern is the spring perch locations.
Wheel Tire Automotive parking light Car Vehicle
Tire Wheel Vehicle Plant Car
Ended up getting the Toyota FJ60 axles. The front is 58-3/4” WMS-WMS and the spring perches are 32” wide to the outsides. 6 bolt pattern and has 4 piston calipers. It is a 9-1/2”ring gear so I don’t think my little SFI 3.4 will be able to hurt it! I’ll make a new thread once I start on the installation as that won’t be until winter.
