I show the following for a '99 Trooper, and I'm pretty sure they apply to my '98 Trooper as well ...
Front Differential: 1.5 Qt. 80W-90 or GL-5
Rear Differential (G80, w/ LSD): 3.2 Qt. 80W-90 or GL-5 w/ Limited Slip additive
TOD/transfer case (ATX): 2.0 quarts Dexron III ATF
I've got some good synthetic 75W-90/GL-5 gear oil (Redline 75W-90) that says it already has LSD friction modifier, so I was going to use it in both front and rear diffs as-is, and I've got their Synthetic D4 ATF for the TOD unit. I wanted to run synthetics because a) I want to run an extended interval change (say, 45k), b) I'm trying to eek out every last bit of gas mileage I can, and c) I've got larger-than-stock (265/70/16) tires that I'm sure put slightly more load on the gears.
Can anyone confirm I have the right capacities for my '98, and does anyone have specific experiences to say that I've definitely got the wrong fluid for any of the above?
Thanks!
Josh
Thanks!
Josh
