1 - 3 of 3 Posts
· Registered
I have a 1990 trooper 5 speed manual 4x4 -- has come up with a noise. When driving and hit a pot hole on the right side a rubbing sound will happen for a couple of seconds and then go away. It is done with speed, I heard the noise and put in the clutch and coasted to the side of the road going about 25 mph. The sound would slow down as the car slow down like it was something rubbing against the tire. But much louder... I thought it was front wheel bearings. Changed them and still the same..Any one have that problem??? Could it be the center bearing for the drive shaft??? I tow it behind a Motorhome.... HELP
· Premium Member
Do you have automatic hubs? If so they could require a repack. In Virginia winters we used to (and still do on occasion, but not as often now that we know the required maint.) have a problem with the hubs becoming "partially engages" - enough to make a horrible sound, but not enough to actually engage. This would only happen when in 2wd. I'd suggest that you take the hub cover off, then the spring loaded part of the hub. Clean them out well, and replace. See if that fixes it.
-Tad
· Registered
I have manual hubs ... But that is a thought...It almost sounds loud like in 4x4... When I was replacing the bearings I noticed that a thin washer between the lock ring and the gear was missing.. Wonder if that makes a difference. It is to hold the drive shaft out... Thats for the info....Tad...
1 - 3 of 3 Posts
