1 - 4 of 4 Posts
Noticed that the back doors rubber gasket along the top of the door and the roof (is that even what its called?) does not stop water from coming when it rains. Its a 99 Trooper. Any thoughts? Is this a normal wear and tear issue? The Gasket doesn't even look worn out.
had the same problem on my 88 trooper. is it just leaking around one door or both? you probably just have to re-align the doors by loosening the hinges just a little and move it around, it may not be meeting the gasket.
No its just leaking on the back door!
1 - 4 of 4 Posts
