1 - 3 of 3 Posts
I have a 99 trooper and installed the permanent overlander roof rack with a thule bar on top. I installed it in the front position right over the front doors. I had quite a bit of wind noise from the rack so I bought a thule x-large wind fairing which quieted the wind noise at slower speeds but now I get a vibration noise from the fairing at freeway speed. Does anyone have a fix please?
I experienced the exact same problem when I intalled my fairing with my Yakima rack. The noise on mine was coming from the lower plastic corners of the fairing vibrating against the metal roof. Easy fix....buy some adesive tape with rubber or foam and lay a small 1-2" strip under each corner. It fixed mine.
1 - 3 of 3 Posts
