This problem started on the way to Moab and contributed to the trip being kind of a bust for me. The idle is very uneven. It drops to almost stall then surges to 1000 plus RPM then drops again. Sometime it evens out to normal for a while but not for long. Frequently when I try to accelerate from a stop, it surges causing the truck to almost bounce. If I try to hold the accelerator steady it gets worse and more violent. I have to accelerate to about 3000 before it evens out enough to drive. This happened in Moab on my first real trail drive and cause me to have to slip the clutch so much that I had to turn back. Thankfully the clutch recovered when it cooled off and dried out.
Anyway, Now I have returned to home I am trying to diagnose this problem.
Have a new Bosch Fuel pump. Timing has been checked and in spot on10. Vacuum is around 16 - 18 mm Hg but surges and drops with the uneven RPMs. I've been working a lot but will have some time this weekend to mess with it. What else should I check and do the get Rodeport to running good again?
On a side note one of the best parts of the trip was meeting some of the wonderful folks from the planet. Really made the problems of the trip diminish. Thanks.
